TractorLinks.com
Order Ford 8N Parts Online
Re: 3pt logsplitter to run off 8n hydraulics?
Bill Rowles
02-17-2013 21:26:50
Forget the screw cone splitter. I have one but will not use it anymore.....too dangerous and too hard to deal with the situation when it gets stuck in the wood.....there is no reverse and even if there was it would be too dangerous to use.
I built a splitter using the Tractor Supply (TSC)3-point splitter to which I added a 10 GPM PTO-driven pump and an oil tank I purchased from Northern Tool. I made a torque-taker arm that is bolted to the pump and rests on the tractor axle housing and a small platform to hold the pump when removed from the PTO shaft. No hose connections to make since the tank and pump are permanently connected to the splitter frame and piping. It works great with the tractor engine running at about 800 RPM....never gets stuck in wood!
