Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Hydraulic question
02-17-2013 13:42:54
Wonder if you could have gotten air in there?
02-17-2013 14:01:57
 Re: Hydraulic question in reply to Jimmyjack, 02-17-2013 13:42:54
Next to impossible to get air in the hyd system since the pump sits in oil all the time unless it is to low and then ya you have air but then a person should check the oil level which I think he said he had refilled
02-17-2013 14:18:07
 Re: Hydraulic question in reply to old, 02-17-2013 14:01:57
I dont agree, if you drain all the oil, and refill it, it could easily get air in it. That would be similiar to running a diesel out of fuel. You have to bleed it to get the air out. Usually you can work the air out of a hydraulic system by working it.
02-17-2013 14:25:19
 Re: Hydraulic question in reply to Jimmyjack, 02-17-2013 14:18:07
You even pull the hyd pump on an N series tractor??? The way they are made it is in fact impossible to get air in the system unless you do not have oil in the system since the pump sits in oil and the oil is well over the top of the pump and the suction parts of the pump are well below oil level. I have pulled more then one system all apart and NEVER had an air lock in the system on and N series tractor
