TractorLinks.com
Show Parts for Model:
Re: Hydraulic question
old
02-17-2013 13:25:15
Pull the right hand inspection plate off. It ha the dip stick for fluid level on it. Start tractor up with PTO in gear and watch for oil moving around. Also make sure the control arm is hooked up like it should be. If you do not have an FO-4 manual get one it has some good pictures of the controls etc
Milk trout
02-17-2013 13:40:47
 Re: Hydraulic question in reply to old, 02-17-2013 13:25:15
okay...did not disconnect anything else though...
old
02-17-2013 13:59:59
 Re: Hydraulic question in reply to Milk trout, 02-17-2013 13:40:47
Ah but the PTO shaft as it went in or out could have hit something and popped it out of place.
milk trout
02-17-2013 14:37:51
 Re: Hydraulic question in reply to old, 02-17-2013 13:59:59
I have no idea where the control valve is or what its or what Im looking at inside...Ill check for fluid movement. If its not moving then what? Also, on the air arguement- My fluid level was waaay low- not even on the dipstick- due to leaky seal..but I did NOT run it that way. I just put 4 gallons of fluid in, she is right on the full line.
old
02-18-2013 08:57:15
 Re: Hydraulic question in reply to milk trout, 02-17-2013 14:37:51
Do you have the I-T FO-4 manual?? If you do there are some good pictures in it as to the control linkage. If you do not have it you need to get it. As for the air I saw you said something about filling it so knew air was not the problems
milk trout
02-18-2013 09:37:13
 Re: Hydraulic question in reply to old, 02-18-2013 08:57:15
I do not have that manual...where can I get it? Thanks again for your help everyone. Oh...one more thing- I have had carb trouble forever- thing rusts like crazy in Florida humidity...just had a master rebuild of it...and it was sand blasted and acid dipped...started her up, a couple of adjustments and it runs MUCH better...wonderin about a timing issue though...while running at a good pace in second or first, when i throttle down she back fire- not every time, once in a while...and 3rd gear it has no power and takes forever to "ramp up" and go... what do you think?
old
02-18-2013 09:53:42
 Re: Hydraulic question in reply to milk trout, 02-18-2013 09:37:13
Most any farm and home store should have that manual or be able to get it as well as a tractor dealer. As for timing refresh my memory what are you working on?? If it is a front mount distributor not likely to be a timing problem but could be a point gap problem. Points need to be set at 0.015 and be sure to check it on all 4 lobes
