TractorLinks.com
Order Ford 8N Parts Online
Re: Odds and Ends questions for my '48 8n
john B ne ind
02-17-2013 12:56:26
The best way it set your tire pressure is to read the tread. Drive on the pavement then onto a gravel drive You will then see how much of the tread is touching the ground and adjust accordingly. I know on my 8-n that I have to run a little more pressure when I have my wheel wts on. I would guess around 10-12 would be a good starting point. To much air and the tread won't lay flat. To little air then the tread will show wear on the sides-end of the tread. If you normally have something heavy like a grader box on the tractor you might need to add a little air so that the side walls don't bulge out.
