TractorLinks.com
Order Ford 8N Parts Online
Re: 3pt logsplitter to run off 8n hydraulics?
kylemorley
02-17-2013 08:00:08
Can you elaborate on these options? What do you mean by going just remotes and skipping live hydraulics being a couple hundred less?
TheOldHokie
02-17-2013 08:18:18
 Re: 3pt logsplitter to run off 8n hydraulics? in reply to kylemorley, 02-17-2013 08:00:08
Live hydraulics is a circuit from the auxiliary pump to the 3pt lift that allows it to operate when the PTO is not turning (i.e disengaged or clutch depressed). That circuit can not carry more than 2.5 GPM or it will swamp the control valve inside the3 tractor and the 3pt won't operate correctly - it will raise and stay there due to the eexcess back pressure in the control valve.
When I use a bigger pump for remotes I add a flow divider valve that splits the pump output into two streams - 2.5 GPM for the live hydraulics and the full flow to the remotes. The flow divider and extra plumbing increases the cost by roughly $200 - the flow divider is a $100 component just by itself. You can simply eliminate the divider and live hydraulics related plumbing and still have 10 GPM "live" remotes but you will not have a "live" 3pt lift. It's also easy to add the divider and second circuit at a later time if you find the money and/or decide you want/need it. Once you have the basic system in place the "extras" are easy - all it takes is $$$$ ;-)
There are a number of configurations for running a log splitter off the tractor - all cheaper and IMO better then using a PTO pump. Give me a call or drop me an email if you want the full rundown.
TOH
301.655.0631 (EST)
oldhokie@verizon.net
