Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 3pt logsplitter to run off 8n hydraulics?
soundguy
02-16-2013 16:47:00
yes it will work / can be made to work.
YES it will be slow.
YES you will have to size the cyl correctly to get splitting force.
full out you make 1500-1700 PSI and 2.85 gpm on a decent N pump.
flow is lower at lower rpm.. though pressure will still be there at reduced flow.
the larger the piston in the cyl.. the more that 1700psi does.. etc.
later tractors and ag hyds are in the neighborhood of 2500 psi.
a pto pump could be added to your N and then you'd have plenty of flow and pressure..e tc.
so.. yes, maybee, yes, yes.
speed is about the biggest sacrifice.. and a lil fuel perhapos.
if just kindling etc.. i think it will be a fun project..
CJ in Michigan
02-16-2013 16:57:20
 Re: 3pt logsplitter to run off 8n hydraulics? in reply to soundguy, 02-16-2013 16:47:00
I use a tow-behind splitter with a Honda motor. Here's a video of a screw-type that runs off a P.T.O.-
kylemorley
02-16-2013 17:40:01
 Re: 3pt logsplitter to run off 8n hydraulics? in reply to CJ in Michigan, 02-16-2013 16:57:20
Actually, I've been considering a conical screw-type. The screw heads seem awfully expensive for what they are, so which way I'll go depends on whether I can find a used screw cone at a decent price.
Jimmyjack
02-16-2013 17:41:37
 Re: 3pt logsplitter to run off 8n hydraulics? in reply to kylemorley, 02-16-2013 17:40:01
If you got bad shoulders now, just wait till you use the screw cone for a while!
