Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1952 Sidemount won't stay running.
Jerry/MT
02-10-2013 12:37:20
You appear to have adone a systematic check.Here"s what I would do additionally.
Did you check to make sure you had the requisite FAT, BLUISH-WHITE SPARK, the color of lightning? check the spark right when it dies. A worn distributor bushing can cause poor running after start up so check the lateral play in the distributor shaft.
By all means check the float setting. M-S carbs are very sensitive to this adjustment.
Have you cleaned the carb thoroughly? That"s the secret to a good carb rebuild (ask GBinMT). That"s probably more important then new parts unless the old parts are obviously damaged or worn.
L.B,
02-10-2013 13:47:08
 Re: 1952 Sidemount won't stay running. in reply to Jerry/MT, 02-10-2013 12:37:20
I called you a thief when you got this tractor,I stand by it I still say you stole it,now less then a week you asking for help. You have some big you know whats to rub it in like that. It runs but quits. You then post it is a fuel problem which it is just so you can rub it in on us more,even when you knew its a fuel problem.Snicker. It is the fuel problem. Stay the course and when it purrs like a fine machine which it is let us know.Did you check the air filter also? Have fun you lucky devil.
Jerry/MT
02-11-2013 16:52:03
 Re: 1952 Sidemount won't stay running. in reply to L.B,, 02-10-2013 13:47:08
Huh?????????
old
02-10-2013 13:36:00
If you go down to the last time he posted you will see he posted the fix which by the way was an in line fuel filter which is well known to cause problems
GB in MT.
02-10-2013 13:48:15
 Re: 1952 Sidemount won't stay running. in reply to old, 02-10-2013 13:36:00
Before I replied......I re-read every post and looked at every pic.....(2 in #)
One of the tractor on the traier, and one close-up of the engine, w/filter.
The filter is orientated the SAME in BOTH pix!!!!!!! SAME type of filter!!!!!!! (Both pix.)
What picture are you refering to???????
Gary
old
02-10-2013 13:55:31
 Re: 1952 Sidemount won't stay running. in reply to GB in MT., 02-10-2013 13:48:15
The only picture I see in this post not the post of a day or so ago. As in down lower where you also answered him but some time after I answered him
Copyright © 1997-2015 Yesterday's Tractor Co.
