| Author |
[Modern View]
| dennis in nc
02-10-2013 12:04:28
184.39.9.222
53 golden jubilee.tires not loaded,no weights ? what is the weight. 2340 close? |
| old
02-10-2013 13:39:59
209.86.226.40
Re: weight in reply to dennis in nc, 02-10-2013 12:04:28
| As per page 6 of the NAA owners manual it weights 2550 including oil, water, -less gas. So if you can believe a ford owners manual you have it right from the company that made it and this is not a reprint by the way |
| soundguy
02-10-2013 14:29:24
107.41.153.148
Re: weight in reply to old, 02-10-2013 13:39:59
| looks like my 2500 dry guess was spot on.. guess it should be after all this time. :) |
| old
02-10-2013 16:33:36
209.86.226.40
Re: weight in reply to soundguy, 02-10-2013 14:29:24
| LOL that is why I collect all these manual so I can come as close as the company that makes them say what it is |
| dennis in nc
02-10-2013 13:33:54
184.39.9.222
| tanks, i think 3,5s will be ok.will know for sure tommorow,when i see it. |
| soundguy
02-10-2013 12:17:21
107.41.153.148
| | i estimate fords like that around 2500 dry... you trying to make weight on a 7k trailer or something? if so.. positioning the load over the axles correctly with respect to tounge weigth is also an important factor. and I'd avoid single axle trailers too.. unless you have a 1 ton drw truck |
| ASEguy
02-11-2013 04:05:47
68.186.162.134
Re: weight in reply to soundguy, 02-10-2013 12:17:21
| I have a Dodge Dakota Quad cab and was thinking about a single axle trailer. Why not a single axle trailer unless you have a one ton with duals? |
| soundguy
02-11-2013 05:17:28
184.247.192.120
Re: weight in reply to ASEguy, 02-11-2013 04:05:47
| | ever see a teeter totter? with 1 axle on the trailer.. you have to do a balancing act with the tractor. with a smaller truck, that can become un-fun / un safe, witht he tounge of the drailer dipping down and swinging up, doing the same to the rear of the truck. A HD truck will not experience this near as bad as the 1/2 ton and smaller trucks like rangers and other near 1/2 ton trucks. |
| dennis in nc
02-10-2013 12:26:20
184.39.9.222
| soundguy
02-10-2013 12:32:40
107.41.153.148
Re: weight in reply to dennis in nc, 02-10-2013 12:26:20
| havn't seen it yet.. how long ago? |
| dennis in nc
02-10-2013 12:42:34
184.39.9.222
Re: weight in reply to soundguy, 02-10-2013 12:32:40
| dennis in nc
02-10-2013 12:41:13
184.39.9.222
| LOOKING AT A 38FT GOOSE 3,5S GOLDEN AND BR,CLOSE TO SAME WEIGHT .35OO D DULLY.AM I GOOD |
| soundguy
02-10-2013 12:51:48
107.41.153.148
Re: weight in reply to dennis in nc, 02-10-2013 12:41:13
| | i tried replying 3 times.. board ate my replies. in short. I pull a 30' gn with my ford duallies. I have pulled a 35' gn loaded with hay for my farrier. sounds fine if you stay legal weight / brakes..e tc. |
