TractorLinks.com
Show Parts for Model:
Re: touch control ? lift acts goofey!!
soundguy
02-10-2013 11:17:10
as zane asked.. hows the friction disc?
is it doing anything?
gutterman
02-10-2013 17:33:40
 Re: touch control ? lift acts goofey!! in reply to soundguy, 02-10-2013 11:17:10
Quoting Removed, click Modern View to seeI don't know about the condition of the friction disc really I don't know how to check it...I was thinking that since it worked at first it was fine, the pull on it is so much that I can't imagine a friction disc holding it in place.
.other than the disc what else could it be? Thanks
soundguy
02-11-2013 05:54:24
 Re: touch control ? lift acts goofey!! in reply to gutterman, 02-10-2013 17:33:40
you don't know about the condition of the friction disc?
i'm sorry.. but if you are blind.. you may need help using the tractor.
the friction disc is a couple inches from your hand when it's ont he 3pt lift lever.
do you have a service manual?
gutterman
02-11-2013 07:00:14
 Re: touch control ? lift acts goofey!! in reply to soundguy, 02-11-2013 05:54:24
Quoting Removed, click Modern View to seeya i know where it is,what I don't know is how to know know weather it's bad or not ...again the pull down when I'm holding the handle is so much that if I could tighten down the disc I wouldn't be able to move the handle. Also the life eases up. Is that from the disc also? Thanks for the help.
soundguy
02-11-2013 09:24:50
 Re: touch control ? lift acts goofey!! in reply to gutterman, 02-11-2013 07:00:14
well.. you may need to get some outside help on this on.
maybee your wife can come out and look and see if the cork disc is there and in compression with the spring and nut and touch control shaft plate.
JMOR
02-11-2013 07:59:55
Quoting Removed, click Modern View to seeThere are several forces at work in the lift control linkage which are acting against the touch control levers eccentric shaft. These forces are trying to push the eccentric toward the front of tractor, where as raising the touch control lever tries to push the eccentric toward the rear. Without either your hand OR the spring/cork washer assembly, the lever will naturally relax to a non-lift/lower position due to the forces described.
