I am redoing the valve train on a 1948 8N that has been converted to 12 volts and has a front distributor.
The gasket set that came with my rebuilding kit has 8 valve seals.
The Ford I&T manual and the
Ford Owners Manual do not say anything about the valve guide seals. I remember reading that the seals only go on the intake valve guides.
Is this correct ? If so, why did they put 8 seals in the gasket kit ?
Thank you for any help you can give me.
