What did you have in mind?
Not much in the way of specialty tools needed for these tractors. Just a good socket set up to 1-1/4", box wrench set, breaker bars of several lengths, screw drivers, a cheater bar, a volt-meter, a couple of crescent wrenches, and you've got most things covered from standard maintenance to some serious repair work.
If you don't have it, the I&T FO-4 Repair Manual and the parts manual are indispensable.
Colin, MN
I have a good supply of hand tools and a lathe I would like to aquire a tool to set the timing I did make a dohikky that sets in the bolt hole on the dist. and step up a 1/4 inch so I could set a strait edge against I use a file for a strait edge clamped in a vise it works but crude
