Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8N second gear
Don Verrico
02-09-2013 14:38:15
So I put the cover back on and when I put it in all the gears except 2nd it works fine. When I look at the gears including the two big ones on top they look fine. I put a magnet down onto the sump -- no metal. I drained all the fluid and everything looks OK.
02-09-2013 14:45:39
 Re: 8N second gear in reply to Don Verrico, 02-09-2013 14:38:15
look at your shift fork.
check the detents. is it slipping?
is the fork broke / bent?
02-09-2013 16:05:18
 Re: 8N second gear in reply to soundguy, 02-09-2013 14:45:39
I'm not sure what to look for. Everything seems OK.
Bill Rowles
02-09-2013 21:36:54
 Re: 8N second gear in reply to Donv, 02-09-2013 16:05:18
You should be able to figure out which shift fork is moving when you move lever to "2". Then determine which gear that fork should move. Closely inspect both gear and fork. If the problem is not obvious to you, get someone more experienced to evaluate the situation.
02-09-2013 17:37:01
thru the internet I won't be able to see your crashbox.
shift it into 2nd and look, then to neutral.
see if the box looks any different to you. :)
