TractorLinks.com
Order Ford 8N Parts Online
Re: 8N second gear
soundguy
02-09-2013 14:11:47
is the shift fork actually engaging 2nd?
shift it in then pull the cover again..
Don Verrico
02-10-2013 06:49:10
 Re: 8N second gear in reply to soundguy, 02-09-2013 14:11:47
when I put the lever into 2nd it is not engaging. I pulled the cover again and took a picture...here it is. When I rock the tractor it rolls like it is in neutral.
carlntexas
02-10-2013 13:15:43
 Re: 8N second gear in reply to Don Verrico, 02-10-2013 06:49:10
Am I the only one that can't see the picture?
soundguy
02-10-2013 10:44:04
dude.. do some observation.
if you are shifting it and the gear is onviously not engaging, take a look at 'what' should be 'where' and solve for 'why not'
look for a slipped fork on a rail.. might be a set screw or something..
Don Verrico
02-10-2013 05:59:35
I put gear shift lever into "2" and I can roll the tractor -- like it is in neutral. Take off the cover and look and everything looks OK. I can take a picture.
Don Verrico
02-09-2013 14:33:22
I don't know if it is. I'll shift it into second then pull the cover...what should I see?
Don Verrico
02-09-2013 14:38:15
 Re: 8N second gear in reply to Don Verrico, 02-09-2013 14:33:22
So I put the cover back on and when I put it in all the gears except 2nd it works fine. When I look at the gears including the two big ones on top they look fine. I put a magnet down onto the sump -- no metal. I drained all the fluid and everything looks OK.
soundguy
02-09-2013 14:45:39
 Re: 8N second gear in reply to Don Verrico, 02-09-2013 14:38:15
look at your shift fork.
check the detents. is it slipping?
is the fork broke / bent?
Donv
02-09-2013 16:05:18
 Re: 8N second gear in reply to soundguy, 02-09-2013 14:45:39
I'm not sure what to look for. Everything seems OK.
Bill Rowles
02-09-2013 21:36:54
 Re: 8N second gear in reply to Donv, 02-09-2013 16:05:18
You should be able to figure out which shift fork is moving when you move lever to "2". Then determine which gear that fork should move. Closely inspect both gear and fork. If the problem is not obvious to you, get someone more experienced to evaluate the situation.
soundguy
02-09-2013 17:37:01
thru the internet I won't be able to see your crashbox.
shift it into 2nd and look, then to neutral.
see if the box looks any different to you. :)
