TractorLinks.com
Show Parts for Model:
Re: charging problem
xring 223
02-09-2013 11:24:45
OK i checked voltage 8.40 I'm running 8V battery took belt off generator jumped relay and it ran in the direction of engine rotation
Bill Rowles
02-09-2013 21:22:25
 Re: charging problem in reply to xring 223, 02-09-2013 11:24:45
If the generator is giving 8.4volts to the 8 volt battery, that seems good enough regardless of the ammeter reading. If you run engine at half-throttle speed with lights on does the ammeter show + chrge and volts remain 8.4 across battery?
carlntexas
02-09-2013 11:39:48
The 8v battery is your problem generator won't charge an 8v.
xring 223
02-09-2013 11:50:40
 Re: charging problem in reply to carlntexas, 02-09-2013 11:39:48
really my brother has a 928N with an 8 volt batt. and his generator keeps it charged just fine
soundguy
02-09-2013 14:28:26
 Re: charging problem in reply to xring 223, 02-09-2013 11:50:40
for gennies with a vreg.. you have to tweak the vreg to get them to charge 8v.
in general.. 8v is a poor bandaid.
I'd make 6 work or go 12.
if it likes 8.. it will love 12...
xring 223
02-09-2013 14:35:20
 Re: charging problem in reply to soundguy, 02-09-2013 14:28:26
I would like to keep it original how would you tweek a cutout relay doesn't have a vreg
soundguy
02-09-2013 14:47:10
 Re: charging problem in reply to xring 223, 02-09-2013 14:35:20
you don't tweak a relay. a 1 wire genny has a 3rd brush you turn up.
xring 223
02-09-2013 16:05:46
 Re: charging problem in reply to soundguy, 02-09-2013 14:47:10
I turned it up all the way
soundguy
02-09-2013 17:09:53
 Re: charging problem in reply to xring 223, 02-09-2013 16:05:46
keep an eye on bat voltage at full charge.. don't want to boil it
