Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Leaky Carb.
02-05-2013 14:48:06
As sound said that is pretty much a device in the carb to make sure if flooded it will drain so you can start it once it has drained. You may have a float problem or you could also have a little dirt/rust in the needle seat causing that. If dirt etc some times pulling the carb drain plug is enough to let ti flow out and then the float work just fine again
02-05-2013 15:11:59
 Re: Leaky Carb. in reply to old, 02-05-2013 14:48:06
Thanks Old - I'll check and see if the float is working like it should. I had the carb apart last week and the float didn't seem to have any fluid in it, so I'll have another look at the seat and valve.
Appreciate your help. Joe
Ken N Tx
02-06-2013 04:08:24
 Re: Leaky Carb. in reply to JoeN'Mo, 02-05-2013 15:11:59
No fluid is suppose to be in the float!!!
02-05-2013 21:00:04
Do not know where you are in Missouri but my e-mail is always open of you need help. I am at the lake of the Ozarks
02-07-2013 15:07:40
 Re: Leaky Carb. in reply to old, 02-05-2013 21:00:04
Old - Thanks for your reply. I"m in Southeast Mo., about 60 miles south of St. Louis.
02-07-2013 15:44:09
 Re: Leaky Carb. in reply to JoeN'Mo, 02-07-2013 15:07:40
Oh so your over there in the swamp land area or maybe where it likes to shake once in a while. So yep a good 200 plus miles from me
02-06-2013 18:08:51
Old, what is your email? I'm an old sailor like yourself. Located in Wentzville, MO
02-06-2013 20:33:28
 Re: Leaky Carb. in reply to LarryNMO, 02-06-2013 18:08:51
My e-mail is always open on here if you use modern you click on my name or if on classic you should see click on e-mail at the bottom of a post. Or
