Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: hitch below PTO?
02-05-2013 12:33:01
You are not crazy and something is missing. The OEM drawbar clevis has a special spring loaded "push and twist to lock" feature for secruing the hitch pin. The part you are missing is the is the special hitch pin - p/n 8N804A. It is inserted through the keyed hole in the underside of the clevis, pushed in against the spring loaded collar, and then turned 90* and relleased to lock it in place. They are available from CNH for $60+ or you can buy one of my shop made repops for 1/3 of that. If you want to roll your own find yourself some 1-1/6" round bar, a 1/4"x 1-1/2" spring pin, and a drill.
02-06-2013 09:35:54
 Re: hitch below PTO? in reply to TheOldHokie, 02-05-2013 12:33:01
Good workmanship on that pin there TOH
02-06-2013 10:54:20
 Re: hitch below PTO? in reply to berryrifter, 02-06-2013 09:35:54
Thanks - I am still learning ;-)
