Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 12V conversion - Engine cuts out
Kurt-NEPA
02-05-2013 11:08:23
Make sure you get a 12 Volt coil that says "No External Resistor Required". Then ditch the step down resistor. I never liked those things anyway.
Do yo have a ballast resistor in the system in addition to the step down resistor? If yes, use the 12V Coil No External Resistor Required" and ditch both resistors.
I would do the coil swap first and then see what happens. I would use a 12V coil anyway, so it only makes sense. If it still cuts out, I would check the ignition switch, condenser, and points.
This post was edited by Kurt-NEPA at 11:09:08 02/05/13.
