TractorLinks.com
Show Parts for Model:
Re: Bulldozer- weak axle
Bulldozer
02-02-2013 07:14:52
Ok, you win, the front axle is not fixed to the frame, but has a center pivot on JD & NH utility tractors
Stand corrected!
Looked up the exploded parts view of the JD 3005
compact utility tractor on the JD website.
This tractor is about as close to the N series as anything on the market, accept for maybe the NH 1500 compact tractor.
The 4WD model has the center pivot housing integal with the differential housing. Appears to be a very heavy duty casting.
The 2WD model has a front axle with a center pivot with a configuration of very similar geometry to the N series, except it is a weldment rather than a casting.
Also looked up the exploded parts view of the NH 1500 compact tractor
The 2WD & 4WD models both have a front axle center support. The 4WD model pivot has zero offset to the front axle. Again the 2WD model front axle geometry is similar to the N series
It is a weldment rather than a casting.
Billy35
02-02-2013 07:35:26
 Re: Bulldozer- weak axle in reply to Bulldozer, 02-02-2013 07:14:52
Tip: next time dozer, you won't need to cave or apologize, if you stick to speaking to only subjects that you know something about & have real hands on experience with, rather than speculation, hearsay, what saw on Internet, etc. HTH
P.S. this applies to other topics that I have seen you "blow hard" on, as well.
