Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: update on 2n with scary noise
02-01-2013 19:44:29
Do a running compression check... DON"T ask how Google it... Its basic diagnostics that few here know much about...
L. B,
02-02-2013 01:45:56
 Re: update on 2n with scary noise in reply to Hobo,NC, 02-01-2013 19:44:29
A running compression check is not needed in this case. He has good #s on his static test. I would say #4 is not getting fuel,and if the cyl and plug are wet then he has no spark . I had a 2N that ran 30 to 45 wet and still would start and run The rings were stuck. Heck even with a finger in the spark plug hole test would tell ya if something major is wrong. Right? JMVHO
02-02-2013 05:19:40
 Re: update on 2n with scary noise in reply to L. B,, 02-02-2013 01:45:56
I agree. Running compression tests test for insufficient volumn entering the cylinder and since his numbers are up his valve train is not suspect. Spark has to verified and if it's good at that cylinder with that plug, then he would need to look for mixture dilution.
02-02-2013 04:52:38
You are not one of the few...
