| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: update on 2n with scary noise
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| BigDanT
02-01-2013 14:20:23
96.60.16.101
With engine running,valve covers off,I can see the tappets rising with the cam lobes,making contact with the bottom of valve stem and raising the valves. I can also see the valves rising when veiwed through plug hole and hand cranking the engine.I'm leaning towards this being a valve issue but just don't know how I get 95lbs, compression if the valves are bad. |
| old
02-01-2013 14:56:13
209.86.226.27
Re: update on 2n with scary noise in reply to BigDanT, 02-01-2013 14:20:23
| Get the #4 cylinder on a compression stroke both valves closed then fill that cylinder with ATF. Watch for ATF to leak out the carb or the exhaust. If it does then you know which valve it is that might be the problem. If it is a valve problem that is. Could also be the intake or exhaust port clogged in the block |
| JMOR
02-01-2013 15:11:45
72.181.173.171
Re: update on 2n with scary noise in reply to old, 02-01-2013 14:56:13
| Quoting Removed, click Modern View to seeDid Dan check tappet clearance on #4 or just #3? If ex too tight & not completely closing, that could dilute mixture enough to not fire. |
| BigDanT
02-01-2013 15:52:26
96.60.16.101
Re: update on 2n with scary noise in reply to JMOR, 02-01-2013 15:11:45
| Jmor...yeah that was one of the first things I checked after start up...all tappet clearance checked good. Going to try Old's suggestion with ATF,maybe one just ain't seating right??? Also going to try pressure testing radiator..thinking maybe an internal head gasket leak,no signs of it though???Thanks Dan |
| old
02-01-2013 15:45:51
209.86.226.27
| Not sure if he did or did not but filling the cylinder with ATF would tell him if it was a valve problem and yes I agree with you just another way to find a valve that does not close all the way |
| tracman
02-01-2013 14:40:23
142.52.81.12
| Go back to Pogun's idea and feel for compression and or vacuum that will tell you if you have enough to get some power out of that cyclinder. Then it is back to spark issues. Could you have enough carbon around the valves to prevent fuel from entering and or exhaust from leaving?? A wet plug will indicate fuel entering but if your exhaust aint leaving you have a nogo. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
