TractorLinks.com
Order Ford 8N Parts Online
Re: Bad Day for my 8N
Tim (UPS) Johnson
01-30-2013 08:19:44
you probably just sucked the life out of the battery,charge it up and try to crank it again
Hec In Omaha
01-30-2013 08:24:53
 Re: Bad Day for my 8N in reply to Tim (UPS) Johnson, 01-30-2013 08:19:44
I forgot to mention that I did charge the battery back up.
Hec
old
01-30-2013 08:48:50
 Re: Bad Day for my 8N in reply to Hec In Omaha, 01-30-2013 08:24:53
Use a jumper cable from the battery + to the starter since it is - ground. BE sure it is out of gear. If it spins over then you have a bad solenoid. Next try a hot wire from the + side of the battery to the coil and do the jumper thing. If it fires up then you have a problem from the coil back to the battery. By the way since this is a front mount do not leave the hot wire hooked up a long time or you may fry the coil but at least that might be enough to get it back to where it would be easy to work on
Hec In Omaha
01-30-2013 09:03:42
 Re: Bad Day for my 8N in reply to old, 01-30-2013 08:48:50
Old,
Thanks for the trouble shooting tips. I will try that when I get home. At least there is no new snow predicted here for the near future!
Hec
