TractorLinks.com
Show Parts for Model:
Re: .040 sleeves from TISCO
kylemorley
01-29-2013 07:10:08
[quote:fdcbc289f7]Bulldozer wrote:
(quoted from post at 06:35:49 01/29/13)
When I had the TISCO sleeves installed by the machine shop I informed them what you had indicated that there was a variation in all the sleeve OD's.
After doing the job the machine shop confirmed there was at least a .005" variation in sleeve OD. Each hole required a machine different setup.
[/quote:fdcbc289f7]
This sort of thing always bothers me because, assuming you are talking about boring the block to take .090 sleeves, you are stuck with the choice of boring the block to standard dimensions, and having your liners not fit (or at the very least need extra honing etc after installation to maintain piston clearance) or bore each hole differently to fit the sleeves, and end up with a non-standard block so there"s no telling what will happen next time some poor fool tries to hammer in a new set of sleeves (unless he can find a replacement set with a similar spread in tolerances).
This post was edited by kylemorley at 07:50:06 01/29/13.
