Hay people after plowing snow the last few days at night been thinking I need to get the back work light working again my 9N got head lights that work but the tail light not the olg girl been redone to 12 volt but still has the 6 volt light on back was wounding what replacement lamp I should use that will fit in the housing I like it cause it has a switch on it so any in put where I can get a 12 volt lamp for it is help full.
Dennis........while I could look it up in the N-MPC, (which is 6V only) just take yer work lite into NAPA and ask for a 12V version. Simple, eh? ........delighted Dell
on my 48 ,i usoldered the old bulb,found one of those high lumen output bulbs at auto zone and simply soldered it in the old housing. replaced the old switch with a newer one. works great so far, i do most of my work at night on the tractor such as mowing or disking etc and it sure helps.
When I first had this tractor the rear work light didn't work so I bought a $40 replacement lamp to go in the original housing, then when the bulb went out again I got to looking at the lense. The lense can be taken off after you uncrimp the sides. The bulb inside is a regular twist in bulb.
