flywheel specs
Anonymous-0
I have an NAA Jubilee that was out of clutch adjustment. I installed a new clutch, pressure plate and throwout bearing even though old parts looked very good. I am now able to get correct free travel, however I am almost out of adjustment already! I checked all linkage for wear or sheared pins allowing shaft to rotate where it shouldn"t. All I can figure is maybe flywheel has been ground too many times. Does anyone have a spec to measure for proper flywheel thickness?
(quoted from post at 13:19:20 01/28/13) I have an NAA Jubilee that was out of clutch adjustment. I installed a new clutch, pressure plate and throwout bearing even though old parts looked very good. I am now able to get correct free travel, however I am almost out of adjustment already! I checked all linkage for wear or sheared pins allowing shaft to rotate where it shouldn"t. All I can figure is maybe flywheel has been ground too many times. Does anyone have a spec to measure for proper flywheel thickness?
here is a sing that has some lyrics about this. "...looking in all the wrong places.....". Seriously doubt a few thousandths here & there can impact the comparatively large throwout bearing/PP finger travel.
What do you know about the history of the tractor?
Could the engine have come from another machine?
Sometime between the 600s and 601s they changed the thickness of the block plate back there.
Went from one about 1/8" thick to about 1/4" thick. If someone dropped a 601 engine in it and didn't use the correct plate you will be pulling hair figuring out how to get the clutch adjusted.
I don't know your NAA as well as the later models but you might check your block plate. I'm thinking it should have the thinner one.
