TractorLinks.com
Show Parts for Model:
12V roundcan conversion question
Tom Beddard ENC
01-28-2013 11:36:40
Rewired squarecan coil by drilling and it went well. My question is do you bypass the "infamous ballast resistor" behind the dash? I think you do but want to be sure! THANKS
Tom Beddard ENC
01-29-2013 15:47:57
 Re: 12V roundcan conversion question in reply to Tom Beddard ENC, 01-28-2013 11:36:40
Thanks guys. I'm going to pick up a NAPA IC-14SB that needs no external resistor & bypass the factory one behind the dash.
jackinok
01-29-2013 06:47:53
when you buy your coil ask for one that doesnt need a external resistor. some 12 volt coils do need one. on mine i eliminated the dash mounted resistor, but one that i bought converted has a resistor mounted on the side of coil. i really believe that any connection you can get rid of helps in the long run.
soundguy
01-28-2013 11:44:22
a round can setup uses no resistor as long as you are using a 6v round can on 6v.. or a 12v round can on 12v.
for instance. napa ic14sb for 12v or napa ic8 for 6v
