TractorLinks.com
Show Parts for Model:
Re: How can I tell if plunger starter switch is bad ?
soundguy
01-28-2013 06:29:51
easy test?
got an ohm meter or test lamp?
#1pull wire off thumb switch and insulate the end.. do not let it touch ground.
be in neutral to test this just in case you mess up on #1.
#2, get ohm meter.. one lead to chassis one leat to tab on switch.. press switch.. should go to 0ish ohms.
or #3, test lamp from bat hot to tab on switch.. pressing it makes the lamp glow.
G6 at Snook, TX
01-28-2013 08:31:17
 Re: How can I tell if plunger starter switch is bad ? in reply to soundguy, 01-28-2013 06:29:51
I endorse Soundguy's process as better than mine. Go with his suggestions.
