8n Coolant Leak
Mr. Natalie
New User
I am in the process rebuilding a '47 8N, "Natalie". I have rebuilt the engine and in the process one of the exhaust manifold studs needed replacing. Go figure the one between #3 and #4, I think this stud is cursed. I put the radiator back on yesterday and noticed that there was some coolant on the floor this morning. It appears I have a leak from that notorious stud. Any ideas on how to fix this? I did put blue thread gunk on there when I put it in, possibly not tight enough? Also the freeze plug next to the drain plug in the block also has a small leak. Seeing as how I had the engine cleaned at a machine shop I did not install this. How would one go about repairing this? Thanks
Mr. Natalie,Get a builders cube or two and put in the radiator.or a small bottle of bars stop leak to seal things up.
it's possible there was a lil erosion or imperfection at the core plug hole, and the rebuilder put the plug in dry. I usually put plugs in with a very thin smear of permatex or copper coat or even red rtv. just a thin smear mind you.. don't want anything breaking off and plugging a cooling passage..
I always put JB weld over the freeze plugs then smooth it real nice before I paint. If you do real nice you can hardly notice the plug is even there once painted up. My local machine shop told me to do that years ago and I haven't had a problem yet. If you don't care about looks just let it go they will rust up and seal themselves after a while
