Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
hyd. lift cyl
kenben
01-27-2013 13:30:02
I bored a little but not to much.Do you suggest buying new or bore a little more?I have the new piston type on the way from this site.
DollarBill
01-29-2013 11:53:32
 Re: hyd. lift cyl in reply to kenben, 01-27-2013 13:30:02
New cylinder is ready to install - You may need to clearance the outer edge of the cylinder for the lift linkage. Some need it, some don't. Easily accomplished with a die grinder or abrasive disk grinder, whatever you have available.
Notjustair
01-27-2013 20:21:09
Mine looked that bad after honing. I reused it and it works pretty darn good. The blade touches the ground after 6 hours - that's good enough for me. If it chews up the oring and needs it again in a few years I will put In a new one. It shouldn't as I have bigger tractors to work with - that is just the yard tractor.
soundguy
01-27-2013 17:44:54
i honed my 8n to get rid of the scratches.. went a lil out of spec.. but a nice fat NH oring sealed fine..
as toh said.. if you go new it will be more $ but perfect.
your call.
russb wa
01-27-2013 17:39:07
I put mine together with some scratches. It works good. So far. Can it will it chew up the Oring? I don't know.
Bob - MI
01-27-2013 16:18:32
I had the same dilemma and had the same gouges in the bore. These run the full length of the cylinder stroke and the o-ring on the piston won't seal correctly.
I bit the bullet and bought a new cylinder and I have been happy. I would suggest that you get a new one as well and enjoy the better performing lift after you are done.
TheOldHokie
01-27-2013 13:44:32
Buy a new one and eliminate the guesswork.
TOH
Bulldozer
01-28-2013 06:56:31
 Re: hyd. lift cyl in reply to TheOldHokie, 01-27-2013 13:44:32
Does the new cylinder come polished , honed or just plane machine finish?
Copyright © 1997-2015 Yesterday's Tractor Co.
