Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 641 voltage regulator
[Return to Forum]
waynemo
01-27-2013 10:45:45
99.189.64.165
I adjusted my regulator voltage output by increasing the spring force and my first attempt increased the voltage to 7.6 to 7.8 volts. This is above Jmor's specs of 7.1 to 7.5 volts. I will try to get within those specs but wonder what would fail with the voltage values above. Could the field coils in the generator and regulator stand these higher values or is it just about over charging the battery?
Another question on B circuit systems about checking the generator output. On A circuit systems, it is easy to just ground the field terminal taking the regulator out of the system and measuring the generator output. What about B circuit systems, could you just put full voltage on the generator field {after disconnecting the regulator} and measure the generator output, or is that too much strain on the generator field windings?
[Reply]   [No Email]
JMOR
01-27-2013 10:56:45
72.181.173.171
Re: 641 voltage regulator in reply to waynemo, 01-27-2013 10:45:45
Quoting Removed, click Modern View to seeYes, "just put full voltage on the generator field" is acceptable, as this is exactly what is being done by regulator at times. Voltage measured under these conditions will largely depend on charge state of the battery, however. If you were to disconnect battery to ARM then generator voltage can reach damaging levels under full field conditions (>20 volts) & in a short time damage gen & regulator. I would NOT recommend such a disconnect.
A GM manual gives "set point" voltages for the VR and also "upper acceptable' voltages, with that being 7.6 volts. It is primarily to prevent overcharging the battery.
  [Reply]  [No Email]
waynemo
01-27-2013 11:38:39
99.189.64.165
Re: 641 voltage regulator in reply to JMOR, 01-27-2013 10:56:45
Thanks jmor that is good information. I think lots of guys here will benefit knowing how to check out generators. In the case of B systems, I would only use the full voltage to field test for a short time to determine if the generator was at fault.
As far as the voltage over the spec in my case, I use the tractor seldom and not for long running times either. I might be satisfied using the higher voltages in order to keep the battery fully charged. I would not think a battery would be damaged in that way with charging voltages up to 8 volts even. I appreciate your input!
  [Reply]  [No Email]
JMOR
01-27-2013 20:10:56
72.181.173.171
Re: 641 voltage regulator in reply to waynemo, 01-27-2013 11:38:39
Quoting Removed, click Modern View to seeAgree. You are welcome!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
