Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: question about oil in water
Dell (WA)
01-26-2013 14:39:12
Stan.........long time ago, you used to haffta put water pump lubricant in yer engine coolant. Modern green anti-freeze already contains WPL. Unless you clean yer engine with special block cleaner, you will still have WPL in yer water jacket. It doesn't hurt to have old WPL floating around.
As fer yer original question, BIG guess, you have a WARPED flathead and yer headgasket LEAKED anti-freeze into yer cylinders and down into yer oilpan. Yer lucky you didn't hydraulic LOCK yer piston and break a crankshaft. While you "might" be able to "skim" yer WARPED flathead (0.065" max), I doubt it. Yer better off byte the bullet and buying a NEW high-compression flathead which also will increase yer 2N's hp from 23hp to 26hp.
As fer the SMOKE, using ATF or MMO (Marvel Mystery Oil) that is NORMAL to smoke all the oil off'n the CARBON that is caked/baked on top of the pistons. ........the amazed Dell
heybusdriver
01-26-2013 15:30:59
 Re: question about oil in water in reply to Dell (WA), 01-26-2013 14:39:12
Thanks Dell, I'll try a straight edge on the head tomorrow as well as my water test.
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
Copyright © 1997-2015 Yesterday's Tractor Co.
