Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: question about oil in water
[Return to Forum]
heybusdriver
01-26-2013 14:21:09
70.71.96.170
To start off with I bought this 2N tractor not running for a couple of years from my friend Jack. When I got it home I checked the oil & found it to be way overfill & dirty.
2nd step
I went to change the oil and when I drained the oil I found it was overfilled because it had about 2 litres of antifreeze in the bottom before oil came out.
3rd step
I got the motor started and fit was not firing on cylinder #1, I poured tanny oil in the cylinders and let it set a few days.
4th step
I started the motor , it smoked like crazy , I figured it must of had a stuck valve & blown head gasket, when I went to remove the head antifreeze leaked out the head bolts,I quickly put the bolts back in to prevent losing all my antifreeze I drained the block. When I took the head off ( didn't see anything wrong with the head gasket), turned over the motor and seen #1 exhaust valve not moving , I gently with a rubber hammer tapped the valve , now it works.
5th step
Yesterday In order to see if the block was cracked (where I couldn't see ) I filled the water jacket full of water, checked this morning and the water was at the same level , put my finger in the water jacket hole and found when I pulled my finger out it was coated with oil. How would the oil get in the water jacket? the block does not have any oil in the crankcase, drain plug still not re-installed. Where did the oil come from ? no water leaked out.
I hope I made this as clear as I could , if some-one could explain it would sure help. TIA ( sorry for the long post)
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
[Reply]   [No Email]
Bulldozer
01-31-2013 09:49:24
24.165.92.6
 Re: question about oil in water in reply to heybusdriver, 01-26-2013 14:21:09
Oil in the water stems from a crack in the block between the oil galley and the coolant jacket.
When the engine is running the oil pressure > coolant pressure ,so the oil flows into the coolant jacket.
When the engine is stopped, the oil pressure goes to zero and coolant jacket is still pressuized.
The coolant then flows into the oil through the same crack.
It is more common to have coolant in the oil than oil in the water, since the coolant molecule is smaller than the oil molecule and the collant passes through crack easier than the oil.
Gas bubbles in the radiator as seen by removing the radiator cap is a result of a leaking head cover gasket, where the high pressure combustion gas passes through the ruptured gasket into the coolant jacket.
[Reply]  [No Email]
jammison
01-31-2013 12:25:19
72.181.173.171
 Re: question about oil in water in reply to Bulldozer, 01-31-2013 09:49:24
Quoting Removed, click Modern View to seeBulldozer, if I understand you correctly, you are saying that the cast iron wall that makes up the oil galley has a crack in that wall & the other side of that wall is the water area? There by allowing the 2 to mix.
[Reply]  [No Email]
Bulldozer
02-02-2013 08:47:31
24.165.92.6
 Re: question about oil in water in reply to jammison, 01-31-2013 12:25:19
Yes, water in the engine oil is bad news.
There are internal passages in the block to suppy oil to the crankshaft journals.
[Reply]  [No Email]
Hobo,NC
01-26-2013 19:56:55
71.30.76.170
Describe what you mean by oil,,, theirs a BIG difference between water pump lube and oil.... IF what you consider oil is black as the ace of spades and sticky its combustion by products...
I have never seen a water pump lube that would not mix with coolant... I have in the last few years seen bars leak that will not mix with modern coolant...
[Reply]  [No Email]
heybusdriver
01-26-2013 15:27:05
70.71.96.170
After posting this , I got to thinking, I went out and opened the drain and blew out all the water and bits of crud (oil chunks) and am doing the test again , I'll know tomorrow the results. Sometimes I'm my own worst analogist.
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
[Reply]  [No Email]
Dell (WA)
01-26-2013 14:39:12
174.24.216.80
Stan.........long time ago, you used to haffta put water pump lubricant in yer engine coolant. Modern green anti-freeze already contains WPL. Unless you clean yer engine with special block cleaner, you will still have WPL in yer water jacket. It doesn't hurt to have old WPL floating around.
As fer yer original question, BIG guess, you have a WARPED flathead and yer headgasket LEAKED anti-freeze into yer cylinders and down into yer oilpan. Yer lucky you didn't hydraulic LOCK yer piston and break a crankshaft. While you "might" be able to "skim" yer WARPED flathead (0.065" max), I doubt it. Yer better off byte the bullet and buying a NEW high-compression flathead which also will increase yer 2N's hp from 23hp to 26hp.
As fer the SMOKE, using ATF or MMO (Marvel Mystery Oil) that is NORMAL to smoke all the oil off'n the CARBON that is caked/baked on top of the pistons. ........the amazed Dell
[Reply]  [No Email]
heybusdriver
01-26-2013 15:30:59
70.71.96.170
 Re: question about oil in water in reply to Dell (WA), 01-26-2013 14:39:12
Thanks Dell, I'll try a straight edge on the head tomorrow as well as my water test.
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
