| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: loaders
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| TheOldHokie
01-26-2013 12:03:47
108.22.203.170
Wagner and Dearborn (aka Ford) made a number of fully hydraulic loaders that will fit on an N-series. Most had single acting lift cylinders but a few of the later models had double action cylinders as an option. The most common ones are:
Dearborn/Ford models 19-23, 19-42,, 19-70, 19-71, 19-97 and 19-105
Wagner models WM-3 and 4
Most of those loaders are the crawl over, jungle gym style pipe frame loaders. The 19-97 and 19-105 are more modern step through designs and far more desirable and they had DA lift cylinders. Depending on condition the pipe loaders start at a couple hundred bucks - the step through loaders a good bit more. Replacement hard parts particularly for the cylinders on any of those loaders can be a challenge.
There are also less common loaders made by Sauder, Paulson, Davis, Superior, Freeman, and probably others.
All of that said the N-series is not well suited to a loader. Lack of good solid mounting points, heavy steering, and terrible gearing and brakes all combine to make it a poor performer. And while it may look like the cheapest solution to your needs you can easily wind up spending more buying a new valve, pump, and/or hoses than you pay for the loader. A lot of times it's simply a better idea to buy a later model loader tractor with better design features.
TOH |
[Reply] [No Email] | |
| NY 986
01-26-2013 19:32:25
67.142.178.27
Re: loaders in reply to TheOldHokie, 01-26-2013 12:03:47
| I do not disagree with your advice. However, I've seen extremely few loaders from that era that were not equipped with a trip-type bucket. Maybe it's where I live. Even on the hundred series Fords and really most other makes from that era. A fellow could be waiting a long time for a suitable full hydraulic loader. I guess we all pretty much agree the OP would be best served by moving on to something a tad more modern. Like I said before if this tractor was in the OP's family since new and had special meaning to have a loader then I understand. I am at the age where running our Farmall M with the old Horn loader has lost it's charm for me. I am hoping for a cab tractor for the current loader this year. |
| TheOldHokie
01-27-2013 05:00:28
108.22.203.170
Re: loaders in reply to NY 986, 01-26-2013 19:32:25
Must be where you live. The models I listed above all have hydraulic buckets and with the exception of the Ford Industrial Loaders (aka Dearborn 19-97 and 19-105) are readily available just about anywhere. The Ford industrial models are less common but still show up on a regular basis. Wagner Iron Works (Milwaukee) made lots of the WM3 and WM4 loaders specifcially for the 9N/2N/8N tractors and both are fully hydraulic. Their follow on step through design Power-Loader models were introduced for the NAA and are also compatible with the N-series.
A Want Ad posted on the Ford forums usually turns one of the jungle gym pipe loaders up in short order. The step through models are only a bit harder to find. Heck, you can even use something like a modern Bobcat loader if you are modestly handy with a torch and welder. The issue there will be finding an adequate source of hydraulic power for the loader and that I can supply ;-) Of course by the time you are done you could have bought a nice used 4WD Kubota or Thousand Series Ford with the money you have invested. That Bobcat loader does look right at home though.....
TOH
| NY 986
01-27-2013 05:19:30
67.142.178.20
Re: loaders in reply to TheOldHokie, 01-27-2013 05:00:28
| I've been to many auctions and enjoy looking through ads but very rarely have I seen what we are talking about. Around here it seems farmers did one of two things. They made do with the existing older outfit or when they considered upgrading the loader they up graded the tractor too. By the 1960's tractors offered features such as high volume hydraulics, power shift, direction reverser, etc. that enhanced loader operation. Some kept the old tractor/ loader combo but more often they were traded off then some residential type bought the old outfit. A few instances some of the older Farmalls received a modern loader because the newer IH 2001 loader readily adapted because the chassis layout was similar to the newer 504, 656, etc.. |
| TheOldHokie
01-27-2013 05:29:18
108.22.203.170
Re: loaders in reply to NY 986, 01-27-2013 05:19:30
| NY 986 said: (quoted from post at 09:19:30 01/27/13) I've been to many auctions and enjoy looking through ads but very rarely have I seen what we are talking about. Around here it seems farmers did one of two things. They made do with the existing older outfit or when they considered upgrading the loader they up graded the tractor too. By the 1960's tractors offered features such as high volume hydraulics, power shift, direction reverser, etc. that enhanced loader operation. Some kept the old tractor/ loader combo but more often they were traded off then some residential type bought the old outfit. A few instances some of the older Farmalls received a modern loader because the newer IH 2001 loader readily adapted because the chassis layout was similar to the newer 504, 656, etc.. |
Just the first example I found - took about 30 seconds on eBay.
Davis Fully Hydraulic Step-Through 8N Loader
Another 30 seconds on Craigslist finds this (overpriced) WM3 about an hour from me. They are easily found if you want one.
TOH
This post was edited by TheOldHokie at 05:43:13 01/27/13. |
| NY 986
01-27-2013 09:07:18
67.142.178.22
Re: loaders in reply to TheOldHokie, 01-27-2013 05:29:18
| You can find (nearly) anything if you want to travel far enough. The E Bay listing you mention would be a day's drive one way and have over 500 dollars worth of fuel spent to get it for me. Not worth it. I checked after church this morning and I see nothing within 125 miles of me. Did not look further away. Nobody is saying they were never made. I am addressing the OP's question in terms of availability in 2013. I do look at ads for things like that as I have an 860 I am thinking about selling and it might be more attractive if equipped with a loader. If the OP wants to search for and find a loader for his N series tractor then he should do as his heart desires. He has been made aware of the alternatives. |
| Ultradog MN
01-28-2013 01:18:14
184.100.109.75
Re: loaders in reply to NY 986, 01-27-2013 09:07:18
| JMO here but I doubt you'd get your money back putting a loader on a tractor to sell it. |
| bofg33
02-08-2013 18:50:34
76.84.213.167
Re: loaders in reply to Ultradog MN, 01-28-2013 01:18:14
| SSB Tractor sells brand new loaders for vintage tractors...looks like a nice product.. comes complete with front pump .. but the price is $4800.. I just recently purchased a 1951 8N with a davis loader seems to work great..my intention was to remove it and put it on my other tractor that has been restored, and then sell the 51...but after hearing all the negatives about the hard steering and seeing it for myself, i think I will just keep it on that tractor that way I can still use my 48 without all the added weight... |
| Ultradog MN
01-26-2013 17:43:42
184.100.109.75
| Excellent advice TOH. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
