TractorLinks.com
Show Parts for Model:
Re: OT----ENGINE LAY OUT
01BIRDDOG
01-26-2013 07:18:07
Quoting Removed, click Modern View to seeI could give a puke for the new yuppy scum HD trash. Not too common to see stuff screwed up from the mfg. like the drive gear on the Andrews cam but it sure happens. Take this and compare it to the XR four cam set up-----start with four cam lobes,four shafts and four gears. Set up degree wheel along with dial indicator, set opening of each cam lobe one at a time, dissemble entire cam chest ant T.I.G. each lobe to gear and press on shaft. Many,many hours to set up one of these engines. To compare these to the above yuppy engines, well you cant, not even in the same world.
