Mr. T. Minnesota
Forum Members,
Several months ago I attempted to tighten the nut on the touch control lever. It would not tighten or loosen. Finally cut the nut off and then could not remove the outer plate. It would not budge with a lot of leverage. Wrapped 3/16ths nylon cord to replace the disc as a temporary fix. Finally found a replacement for the disc without wrecking the outer plate and buying a new assembly @ about $30.00. Used a 2 3/8 X 3/16ths O ring. It was a tight fit, but appears to be a good replacement @ $2.50. Any thoughts on this remedy.
Mr. T. Minnesota
Mr. T. Minnesota
