Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N sleeves
xj43
01-24-2013 05:54:16
I just went through the same ordeal. Mt sleeves were removed and had oversize pistons in the bare block. The pistons were stamped .083 on top. there was a pretty good ridge around the top of the bore were the lip of the sleeve used to set. Mine was worn bad enough that I had to put custom .125 sleeves from melling back in. It turned out real nice but it wasn't cheap
TheOldHokie
01-24-2013 06:03:43
 Re: 8N sleeves in reply to xj43, 01-24-2013 05:54:16
xj43 said: (quoted from post at 09:54:16 01/24/13) I just went through the same ordeal. Mt sleeves were removed and had oversize pistons in the bare block. The pistons were stamped .083 on top. there was a pretty good ridge around the top of the bore were the lip of the sleeve used to set. Mine was worn bad enough that I had to put custom .125 sleeves from melling back in. It turned out real nice but it wasn't cheap
I'm a little confused here. The difference in the OD of the .040 wall and .090 wall OEM sleeves is .100. Are you telling me your block was worn more than .100 and it could not be rebored for the OEM .090 wall sleeves?
TOH
This post was edited by TheOldHokie at 06:10:00 01/24/13 3 times.
xj43
01-24-2013 07:44:58
 Re: 8N sleeves in reply to TheOldHokie, 01-24-2013 06:03:43
yep
billy boy2
01-24-2013 17:24:52
 Re: 8N sleeves in reply to xj43, 01-24-2013 07:44:58
This one did end up being sleeveless. I feel better now that I realize it wasn't just my poor vision. I have another that was running, but developed a bad rod knock. It's ready to go on the table tomorrow. I'm wondering if the first one will have enough meat to bore for.090s. Between the hole blasted at the top of the bore and a big landing ridge across from that. I'll save it for last.
xj43
01-25-2013 05:51:18
 Re: 8N sleeves in reply to billy boy2, 01-24-2013 17:24:52
I also have the .090 sleeves that came with my rebuild kit. I'll sell cheap if you need them.
billy boy2
01-25-2013 17:36:06
 Re: 8N sleeves in reply to xj43, 01-25-2013 05:51:18
I'll keep that in mind. I'll measure and see. I have to pull the crank from that one for the second one. It has a rod bearing spun and is a rough .090 plus undersize on #4.
xj43
01-25-2013 05:47:24
If you can't save it I have the part number for the .125 melling sleeves. Just get a good machine shop.
Copyright © 1997-2015 Yesterday's Tractor Co.
