TractorLinks.com
Show Parts for Model:
Re: 46 2N coil
Charles Krammin
01-23-2013 17:46:06
Are you using the right terminolgy, when you state 2 ballast resistor? A 6 volt coil in a 12 volt conversion, requires a 12 volt stepdown resistor to 6 volts (acts and looks like a ballast resistor), but with more resistance than a standard ballast resistor and the 2 in series (out one, in next one), apply the needed hot running resistance to a 6 volt coil. Testing resistors, resistance with a digital tester (when cold) might determine this. Testing the "voltage to the top of the coil" (when running), with an analog (dial type)meter should be about 4.5 volts. (digital tester give eratic measurement, when running.) I feel these 2 resistors (12 to 6 volt and ballast resistor), with a 6 volt coil are a better choice than a 12 volt coil, with a ballast resistor since more of the heat is disapated in the resistors, than the coil. The front mount coil also suffers from more heat from the radiator If you have 2 "standard ballast resistors" you do not have enough total resistance for a 6 volt coil, which will cause overheating and failure at operating temperature. My experience is that it is hard to find a good square front mount 12 volt coil, but if you do switch I would recommend the ballast resistor. Personally I like the 6 volt "original FoMoCO" resistor as I feel it has a better insulator between the windings.
HTH
Charles Krammin SW MI
Charles Krammin
01-24-2013 06:13:32
 Re: 46 2N coil in reply to Charles Krammin, 01-23-2013 17:46:06
I mistakenly said I liked the "FoMoCo" 6 volt resistor, when it should have read "FoMoCo original 6 volt coil"
JMOR
01-24-2013 07:43:30
 Re: 46 2N coil in reply to Charles Krammin, 01-24-2013 06:13:32
Quoting Removed, click Modern View to seeWhen last time measured? That sounds awfully high to me.
"Testing the "voltage to the top of the coil" (when running), with an analog (dial type)meter should be about 4.5 volts. (digital tester give eratic measurement, when running.) "
