| Ford 9N, 2N & 8N Discussion Forum |
Topic: 46 2N coil
[Return to Forum]
| Author |
[Modern View]
| Tom Beddard ENC
01-23-2013 17:11:21
173.219.98.53
My 46 2N front mount converted to 12volt,kept 6volt coil with 2nd ballast resistor runs fine but when coil gets hot it quits. I know the coil is going bad. My question is if I replace with a 12volt squarecan will I still have the same problem eventually or are the new 12volt squares more reliable? Thanks |
| Tom Beddard ENC
01-24-2013 12:45:45
173.219.98.53
Re: 46 2N coil in reply to Tom Beddard ENC, 01-23-2013 17:11:21
| Thanks everyone for the replies & tips. I have an old squarecan Daddy had packed back & I think I'll try to do a round coil conversion. I found the posts in the archives which looks fairly simple, just a little time & work. |
| Jim in Eastern North Caro
01-23-2013 19:23:03
75.110.91.62
| Hi neighbor from 20 miles away! I converted to 12 volts about 1990, replaced the 6v coil with 12v coil from Ford dealer, and used two resistors (the white ceramic and the tubular with wire wrapped around it). Lasted fine without complaint until converted to electronic ignition last year. It was working great for 22 years, and worked fine when I took it off, kept in a box with the old points in case the EI takes a vacation. It'd probably take 15 minutes to convert back (by-passed both resistors with new round 12v coil, but left them there for potential need). |
| Dell (WA)
01-23-2013 17:53:44
71.212.40.136
| | Tom........unfortunately, neither the original 6-volt nor the modern 12-volt squarecan coil are as reliable as we'd like them to be. BOTH need the "infamous ballast resistor". Your current 12V conversion is using the WRONG 12-to-6V converting resistor. Most tractor parts stores do NOT sell the correct value. I recommend a 2.5-ohm, 50-watt 12-to-6V converting resistor made from Radio Shack (2ea 5-ohm resistors in parallel) for use with the original 6V squarecan coil. It should be intuitively obvious, you do NOT use a 12-to-6V converting resistor with a 12V coil as you will have weak sparkies. BTW, it takes about 1-hr of operation for the internal insulative tar to melt and cause weak sparkies. .......Dell, yer self-appointed sparkie-meister who knows 8-ways to convert to 12V and they all work the first time |
| Charles Krammin
01-23-2013 17:46:06
69.174.184.231
| Are you using the right terminolgy, when you state 2 ballast resistor? A 6 volt coil in a 12 volt conversion, requires a 12 volt stepdown resistor to 6 volts (acts and looks like a ballast resistor), but with more resistance than a standard ballast resistor and the 2 in series (out one, in next one), apply the needed hot running resistance to a 6 volt coil. Testing resistors, resistance with a digital tester (when cold) might determine this. Testing the "voltage to the top of the coil" (when running), with an analog (dial type)meter should be about 4.5 volts. (digital tester give eratic measurement, when running.) I feel these 2 resistors (12 to 6 volt and ballast resistor), with a 6 volt coil are a better choice than a 12 volt coil, with a ballast resistor since more of the heat is disapated in the resistors, than the coil. The front mount coil also suffers from more heat from the radiator If you have 2 "standard ballast resistors" you do not have enough total resistance for a 6 volt coil, which will cause overheating and failure at operating temperature. My experience is that it is hard to find a good square front mount 12 volt coil, but if you do switch I would recommend the ballast resistor. Personally I like the 6 volt "original FoMoCO" resistor as I feel it has a better insulator between the windings. HTH Charles Krammin SW MI |
| Charles Krammin
01-24-2013 06:13:32
69.174.184.231
Re: 46 2N coil in reply to Charles Krammin, 01-23-2013 17:46:06
| | I mistakenly said I liked the "FoMoCo" 6 volt resistor, when it should have read "FoMoCo original 6 volt coil" Charles Krammin SW MI |
| JMOR
01-24-2013 07:43:30
72.181.173.171
Re: 46 2N coil in reply to Charles Krammin, 01-24-2013 06:13:32
| Quoting Removed, click Modern View to seeWhen last time measured? That sounds awfully high to me.
"Testing the "voltage to the top of the coil" (when running), with an analog (dial type)meter should be about 4.5 volts. (digital tester give eratic measurement, when running.) " |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
