TractorLinks.com
Show Parts for Model:
Re: What a fan will do to your radiator...........
TheOldHokie
01-22-2013 16:07:36
You know it ought to be pretty simple to drill and tap the end of the shaft for a #10 machine screw and a suitably sized flat washer. I wouldn't even be surprised to find a countersink on the end to help you start the drill bit :shock: Or if the shaft sticks out far enough send it to me along with the pulley and and I'll put a snap ring on the end for ya ;-)
TOH
Bruce (VA)
01-22-2013 18:57:54
 Re: What a fan will do to your radiator........... in reply to TheOldHokie, 01-22-2013 16:07:36
If the rebuild shop can't locate an OEM shaft w/ a keeper pin in his supply room, I will try the screw & washer trick. And if that won't work, I will take you up on the offer! Tnx much.
soundguy
01-22-2013 16:14:07
your neighbors must love you. :)
TheOldHokie
01-22-2013 16:46:12
 Re: What a fan will do to your radiator........... in reply to soundguy, 01-22-2013 16:14:07
Once my closest neighbor discovered the shop he brought me lots of things. Then he and his wife had a "failure to communicate" and he moved out. So now I'm lonely with just a couple of lazy lay-about locals to keep me company,,,,
TOH
soundguy
01-23-2013 05:31:56
 Re: What a fan will do to your radiator........... in reply to TheOldHokie, 01-22-2013 16:46:12
good looking company. I'm an animal person!
Bob Harvey
01-22-2013 16:54:59
As long as those yocals know how to 'fetch' a beverage, you are doing OK !!
