Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: What were they thinking?
TheOldHokie
01-22-2013 05:47:19
ZANE said: (quoted from post at 19:12:10 01/21/13) I'll bet that if the TheOldHokie put his mind to it he could make us a set of gears to about half the speed of the 8N four speed reverse??????
Zane
Thanks for the vote of confidence Zane :oops: I have put my mind to it and have produced gearing for 5 prototype gearboxes. In keeping with the Zane Sherman tradition of "fun" product naming I dubbed it the HokiePokie :roll: The gears are made and all that remains is to find time to finish the gear carrier ant the modiications to the Ford PTO shifter and linkage mechanism. Then it's install and test the thing. The reduction ratio is 3.5:1 in all gears forward and reverse so the speed reduction is significant - e.g. roto-tilling speeds.
TOH
Click on the thumbs for a bigger image.
[URL=http://s4.photobucket.com/albums/y110/TheOldHokie/Hokie%20Pokie/IMG_1273.jpg][/URL] [URL=http://s4.photobucket.com/albums/y110/TheOldHokie/Hokie%20Pokie/IMG_1292.jpg][/URL] [URL=http://s4.photobucket.com/albums/y110/TheOldHokie/Hokie%20Pokie/IMG_1277.jpg][/URL] [URL=http://s4.photobucket.com/albums/y110/TheOldHokie/Hokie%20Pokie/IMG_0881_1.jpg][/URL]
This post was edited by TheOldHokie at 05:50:24 01/22/13.
ZANE
01-22-2013 17:45:05
 Re: What were they thinking? in reply to TheOldHokie, 01-22-2013 05:47:19
I knew you could do it!!!!!
Hope you get it into production before I die!
I've always wanted to use a tiller behind my 8Ns.
Zane
Cliff(VA)
01-22-2013 07:18:24
TOH,
How do you shift that thing? Looks interesting.
Cliff(VA0
TheOldHokie
01-22-2013 09:37:09
 Re: What were they thinking? in reply to Cliff(VA), 01-22-2013 07:18:24
Don't know for sure yet :oops: The reduction gear shifter is the sliding collar that is splined to the output shaft and it shifts the same way the PTO shifts.
  1. When shfted forward it engages the transmission output shaft directly via a set of dog clutch teeth locking the gearbox output shaft to the transmission output shaft in a 1:1 drive. The planetary eduction gears are not engaged and simply spin free.
  2. When shifted rearward it disengages the dog clutch teeth from the output shaft and engages the external gear with the sun gears. That produces a 3.5:1 reduction on the transmission output speed.
The OEM shift rail for the PTO has to be rolled to the side similar to the the NAA to get clearance for the gearbox and I've already munged the PTO housing shown in the pictures to do that. Building a modified linkage is one of the remaining efforts. Then a second linkage gets added, probably on the right side, for shifting the reduction gearbox. It's only been a bit over 3 years since I first embarked on this project so things are moving right along :roll:
TOH
PS> Any resemblance to the Howard planetary reduction gearbox used on the NAA and later tractors is pure coincidence.....
JMOR
01-22-2013 06:46:22
Quoting Removed, click Modern View to seeLooks like you maybe already sold one to make this Model T tractor go so slow! :lol:
http://www.youtube.com/watch?v=iBcYQD505Ns
JMOR
01-22-2013 06:45:58
TheOldHokie said: (quoted from post at 09:47:19 01/22/13)
Zane
TOH
This post was edited by JMOR at 06:47:07 01/22/13.
TheOldHokie
01-22-2013 09:42:05
 Re: What were they thinking? in reply to JMOR, 01-22-2013 06:45:58
Close but I'm shooting for a bit lower ground speed - something under 1 MPH @ 1500 engine RPM in first gear.
TOH
Copyright © 1997-2015 Yesterday's Tractor Co.
