TractorLinks.com
Show Parts for Model:
Re: 2N Hour Meter
Lynn Patrick
01-21-2013 12:07:33
Something's not right here! All 3 tiny stove bolts mounting it in the dash came right out and the 3 even tinier bolts holding the back on also came out without any damage!
It's 2 wires clearly marked inside as Battery and Ground. They were broken off flush w/the case & looked like one.
My question still is do I hook it to the 12 volt or 6 volt side?
Thanks for the quick response!
soundguy
01-22-2013 16:12:52
 Re: 2N Hour Meter in reply to Lynn Patrick, 01-21-2013 12:07:33
if it's a 6v hour meter, and you run it on 12, if it's mechanical.. it will count too fast.
running it thru a resistor is dubious as resistors drop voltage based on load. IE.. there is no '6v dropping resistor. ).
you COULD build a vreg out of a couple radio shack parts and feed it and be fairly accurate.. or get a 12v meter from napa like I did for my 951 :)
