Drawbar Hanger
Could someone post a dimensioned drawing of a drawbar hanger? I'm gathering material and dimensions to make a bracket for mounting a Meyer snow plow on the 2N. I plan on using the bolt pattern from a drawbar hanger for the rear pulley, so the cable doesn't cut into the diff.
Thanks in advance,
carpetfarmer
I know this ain't the prettiest but I used this on my 8n and 4000 for a couple of years until I could located the proper bracket. It's just a piece of angle with a couple of J bolts to the lower arms.
Kirk
Thanks for the picture. That's pretty similar to what I plan on doing as well, except I'm probably just going to attach the cable directly to the 11 hole drawbar.
My appologies, in reading through my original post again, I realized that I didn't exactly specify what I was trying to say. I'm looking for the dimensions for the portion that bolts on around the PTO (the diamond and mounting bolt holes), so I can cut out my own plate.
Thanks again,
carpetfarmer
