Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Multimeter issues with coil readings-resistor questions
01-19-2013 19:37:21
Did a bunch of reading tonight. Sounds like 2.7-3.3 ohms is best. And also sounds like 1.7 is about the normal HOT resistance for a ballast resistor, I was using 1.0 in my calculations...
1.2 ohm coil with 1.7 resistor puts me at 2.9 ohms.
1.8 ohm coil with 1.7 resistor puts me at 3.5 ohms, a touch high.
I'm going to to with the 1.2+1.7 and see how it goes...
Also going to check the alternator charging.
01-19-2013 20:15:32
 Re: Multimeter issues with coil readings-resistor questions in reply to Eriklane, 01-19-2013 19:37:21
Quoting Removed, click Modern View to seeYou will not normally see 1.7 ohms hot for the 12250 ballast........when it is at 1.7 it is glowing red & will set paper on fire if in contact. 1 ohm is reasonable to use for operating-hot resistance. BTDT
