Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Multimeter issues with coil readings-resistor questions
JMOR
01-19-2013 18:31:15
Quoting Removed, click Modern View to seeMeasuring low resistance values "accurately" is not simple or easy. Just your test leads, the resistance of the contact between probes & coil terminals can swamp the low number that you are trying to read. A very good reading can be made by using a power source and two meters. Power the primary through an ammeter with one set of leads and connect a voltmeter with a second set of leads directly to coil primary terminals and read amps & volts. Divide , V/I to obtain Ohms.
