Taking off manifold
Anonymous-0
I was taking off the manifold today to check for cause of ticking sound.Nut at #4 was turning stud. I've read in archives to drain radiator fluid before removing stud. Do I have to drain the whole radiator? How difficult is it to replace the stud? Any tips? Thank you.
Drain cooling system because the manifold studs can/do go into the water jacket. As for how much I drain it all just to be sure not to loose any and or cause other problems. The stud is a simple stud and easy to replace but you need a tread sealer so the stud does not leak. Also brass nuts help with that problem in the future
just drain it past the manifold levl.
no biggie to put a stud back in... pucky and seat it with a double nut and go..
(quoted from post at 21:37:29 01/19/13) I was taking off the manifold today to check for cause of ticking sound.Nut at #4 was turning stud. I've read in archives to drain radiator fluid before removing stud. Do I have to drain the whole radiator? How difficult is it to replace the stud? Any tips? Thank you.
Just remove the stud and let it drain itself to the level of the manifold. Put a pan or bucket under the engine to catch the old coolant if need be. I doubt you will get more than a couple quarts.
TOH
I would just drain the block , put a pail underneath the drain cock loosen the plug.
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
Yeah , I know that it is a 46.
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
