Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Dry ice blasting to remove paint
[Return to Forum]
leoy1142
01-19-2013 13:50:33
64.12.116.20
Does anyone know if you can use a regular bead or sand blaster with dry ice to remove the pait on a 8N.
[Reply]   [No Email]
Walston
01-20-2013 11:43:53
173.81.71.179
 Re: Dry ice blasting to remove paint in reply to leoy1142, 01-19-2013 13:50:33
Dry ice is frozen CO2. Make sure you do it in a well ventilated area so you don't create an oxygen deficient atmosphere. That can be deadly.
[Reply]  [No Email]
itmeagain
01-19-2013 18:53:55
198.204.223.148
Effectiveness
The effectiveness of dry ice in removing paint depends on the thickness of the paint layers. If the layers are thin and the type of paint isn't tough, the dry ice can remove the substance at a rate of 300 square feet per hour. Thick layers created from tough types of paint may be removed at a rate of one square foot per hour. Some paints can be more difficult to remove than others and may leave traces of the paint behind. It takes about five pounds of dry ice per minute. This restricts the types of jobs that can be completed because there would be too much time and expense.
Dry Ice Blasting
Dry ice blasting is used mostly for stripping paint from vehicles and even airplanes. To start the operation, set the blaster at the lowest level before pouring the ice pellets into the reservoir. The pellets will be converted into dry ice and come out of the machine as a vapor once you begin the paint removal.
Hold the blaster over the surface that needs to have the paint removed and gradually increase the pressure as the paint starts to disappear. Move the blaster nozzle back and forth slowly over the area to ensure that all of the paint is removed.
Safety
Although technically, the dry ice blaster is the safest way to remove paint, there is always a danger with any equipment that uses pressure. Wear goggles and heavy gloves for protection.
Never start the device on high pressure. It doesn't matter how many times you have used this type of blaster, all surfaces react differently and you could damage the surface you are removing paint from. You could also be caught off guard if you are not ready for the pressure coming out of the blaster.
[Reply]  [No Email]
leoy1142
01-22-2013 09:26:49
64.12.116.20
 Re: Dry ice blasting to remove paint in reply to itmeagain, 01-19-2013 18:53:55
Thanks for your reply. Can a person use a regular bead blast with dry ice.
[Reply]  [No Email]
kylemorley
01-20-2013 07:46:31
96.61.89.165
The dry ice is expensive - 50¢ a pound or so, and the rule of thumb is it will take 1000 lbs per 8 hours of blasting!
Also not much good on rust.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
