TractorLinks.com
Show Parts for Model:
Re: Common causes of leaking carb?
Britcheflee
01-19-2013 08:24:11
When you take it apart remove the pin which holds the float in place and gently lift out the float and give it a shake - if it is heavy or you hear liquid sloshing around inside then you have a pinhole leak in the float - if that is the case you can get the gas out and once dry clean the area out and see if you can re-solder it - I was successful doing that to mine.
Lee
