8n split behind trans
MI-B ill
New User
I am getting ready to switch rear differential/axles based on recommendations from this board. It appears that splitting the 8n behind the trans is a simple task once supports are worked out. Questions; what is necessary for reassembling. Prelims; pull PTO shaft? pull drop hyd. pump? pull side covers? Replace Gaskets. Any other parts likely needed? Thanks Bill in SW Mi
Be sure it is level front to back before splitting makes it push together much more easily. Drain the oil. drive wedges in between front axle and front frame so that the front doesn't flop over.
(quoted from post at 18:16:16 01/16/13) I am getting ready to switch rear differential/axles based on recommendations from this board. It appears that splitting the 8n behind the trans is a simple task once supports are worked out. Questions; what is necessary for reassembling. Prelims; pull PTO shaft? pull drop hyd. pump? pull side covers? Replace Gaskets. Any other parts likely needed? Thanks Bill in SW Mi
Had to go back and find that post... Its your call but it is a EZ swap to swap the trumpets as a assembly (No messing with axles, seals and brakes).. Either will depend on were and the equipment you have on hand to make the swap...
EZ way to split
[/img]
I would be interested in seeing exactly how that
tongue dolly is mounted to the tractor. Thanks
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
Overkill as usual... :lol: Look'n at the pix I may cut the crank handle off and weld a nut on it so I can crank it with a ratchet :idea: I had to move it forward so the crank handle would clear the fender...
[/img]
