TractorLinks.com
Show Parts for Model:
Re: Installed new head gasket - Radiator fluid leaking
HeyObie
01-18-2013 14:01:31
Well, I bit the bullet. 1- pulled the head
2- had .008 milled off ($50). Had some warped. It took 5-6 passes at .001 for the milling machine to to get it clean
2a - checked to make sure pistons did not hit head
3- Bought a Felpro gasket ($16) as recommended
4- Sprayed both sides of the gasket with copper gasket maker
5- cleaned block and head with acetone
6- Torqued to 75 lbs cold engine
7- ran it for 15 minutes
8- torqued to 75 lbs warm engine
It looks great so far.
Thank you all for the advice. I think this should be the recommended procedure for novices
Obie
