Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Common causes of leaking carb?
[Return to Forum]
Jim Carswell
01-18-2013 12:35:01
173.210.188.122
When I turn on my fuel valve gas starts leaking out from somewhere behind the carb, tractor doesn't start. Before I start taking it apart is there anything I should be looking for specifically? It sat outside all summer - maybe the gaskets/seals dried up?
TIA,
Jim
[Reply]   [No Email]
Britcheflee
01-19-2013 08:24:11
67.187.170.181
Re: Common causes of leaking carb? in reply to Jim Carswell, 01-18-2013 12:35:01
When you take it apart remove the pin which holds the float in place and gently lift out the float and give it a shake - if it is heavy or you hear liquid sloshing around inside then you have a pinhole leak in the float - if that is the case you can get the gas out and once dry clean the area out and see if you can re-solder it - I was successful doing that to mine.
Lee
  [Reply]  [No Email]
L. B,
01-19-2013 01:19:58
64.187.79.169
Take it apart it needs service at this point anyway, 5 mins time and ya should have a idea.
  [Reply]  [No Email]
old
01-18-2013 15:23:48
209.86.226.18
You say carb leaks from behind sounds like a bad or dried up carb gasket. But also as Dean said and may have a float sticking and since it sat a long time maybe ever very rusty in side which will cause odd problems
  [Reply]  [No Email]
Dean
01-18-2013 12:54:11
152.216.3.5
Fuel leaking from the carburetor when the fuel valve is opened is usually caused by failure of the float valve system. This can be a sticking, or damaged float assembly, loose float valve seat, damaged float valve needle, dirt in the float valve, etc.
Dean
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
