Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
why two diff 6 volt round coil from NAPA
Steve Andress
01-18-2013 11:56:58
I see NAPA sells IC7 and IC7SB. Both are 6 volt. The SB says wo external resistor. Is the only diff primary resistance? If so can you find out what the resistance is before purchacing?
greg durdik
01-19-2013 19:34:35
 Re: why two diff 6 volt round coil from NAPA in reply to Steve Andress, 01-18-2013 11:56:58
The SB in the Napa ignition line stands for "Silverline Boxed" it is their second line. years ago the difference was as an example distributor caps had aluminum contact Vs brass and the plastic material hand less resistance to carbon tracking as the premium line.
Dell (WA)
01-18-2013 13:56:59
Steve........WHY do you think you need to know the resistance of a 6-volt rated round can ignition coil??? Iff'n yer trying to run it on a 12V ignition system, buy their 12V rated coil and fergitt about resistance. ........sheesh, respectfully, Dell, sparkie-meister
JMOR
01-18-2013 14:04:53
 Re: why two diff 6 volt round coil from NAPA in reply to Dell (WA), 01-18-2013 13:56:59
Quoting Removed, click Modern View to seeEasy there, Trigger....maybe it is "want" instead of "need".
And one should always verify, since many coils are marked.marked as 12v, when they may have resistances from 1/2 Ohm to over 4 Ohms and that results in a huge current range from work to burns up something!
JMOR
01-18-2013 12:09:50
Steve Andress said: (quoted from post at 15:56:58 01/18/13) I see NAPA sells IC7 and IC7SB. Both are 6 volt. The SB says wo external resistor. Is the only diff primary resistance? If so can you find out what the resistance is before purchacing?
If you find a decent parts person at NAPA who knows the paper catalogs vs just computer, they can look up the coil specifics. I have stood there beside them & read the coil resistance specs in their catalogs. The SB (I think means Simple Black) is their so called 2nd line product, but for sure it means cheaper cost (~$18) than the non SB or 1st line ($50) coils. I believe the electrical characteristics are the same. Guarantee likely shorter.
This post was edited by JMOR at 12:21:04 01/18/13.
